Re: Is it still necessary to Re-torque head after
Posted by partsman on February 13, 2005 at 07:36:24 from (207.179.147.153):
In Reply to: Is it still necessary to Re-torque head after over posted by ddg on February 13, 2005 at 07:10:13:
Yup,, it's still a good idea to retorque. After the engine warms up the heat will cause expansion and make things move about.
to retorque, just set the torque wrench to the same spec you used the first time and check hem all in he proper order. Some may tighten a bit more, some might not.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
