Farmall Tractors Discussion Board
Farmall 400 Chugs When Throttle is Advanced
Posted by Larry on November 30, 1999 at 20:22:20 from (208.164.249.157):
I have a Farmall 400 that "chugs" or "flutters" when the throttle is advanced and then it settles down somewhat. There are no obvious popping, coughing, or smoke. It just chugs.
The idle is not too smooth either. The engine RPM seems to fluctuate slightly when idling.
The engine starts on the first try.
The engine was completely tuned-up (plug, wires, distributor...). The fuel tank was cleaned out as it was emitting red rust. The head was also reworked.
Any suggestions for correcting the chugging problem?
Thanks in advance.
Post A Followup
: Re: Farmall 400 Chugs When Throttle is Advanced
