Re: 4166 steering
Posted by redfarmer on February 13, 2005 at 13:26:30 from (207.69.136.201):
In Reply to: Re: 4166 steering posted by P Backus on February 12, 2005 at 19:39:29:
Thanks for your input and yes I do have a service manual from IH.As for why the steering rod bent maybe this might help explain it.One guy responded on the internet that after the lack of pressure the next thing he would suspect was the rear steering cylinder.The other day I talked with a dealer mechanic who remembered working on one and he said the same thing but explained it like this.If the seals in the cylinder are leaking and you are in four wheel steer,when the front wheels are turning the rear cylinder doesn't respond because of the leakage and so an extreme amount of pressure is put on the rod thus bending it at the weakest point.After learning this I have decided to also reseal both steering cylinders while I have in the shop.Thanks for your responses and hope this info might be of help to you.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
