Re: Sheller
Posted by Jeb2N on February 14, 2005 at 03:34:16 from (68.101.4.135):
In Reply to: Sheller posted by SproutW on February 13, 2005 at 20:45:06:
Well, most of the 2-hole shellers were belt driven units as they were higher capacity. Still, most of the single-hole units had an optional pulley that could be bolted to the regular flywheel and used instead of the hand crank (ever notice how lots of the hand cranks are easily removable?). If you don't have or can't find an optional bolt-on pulley, you can usually get away with runnin a 2" wide flat belt around the rim of the big flywheel but this greatly decreases the speed of the unit. However, that can also be a benefit as it gives you more time to run through that batch of corn so more people get to see it running. All in how you look at it.
If you are looking to purchas another unit to shell off of the tractor, check out most any of the old wooden box units, or some of the JD units as they had mounting brackets on the flywheel for the optional pulley if i'm not mistaken and they are fairly common.
Jeb
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
