Farmall Tractors Discussion Board
Re: S.M gears
Posted by Village Blacksmith on November 30, 1999 at 21:16:05 from (205.188.199.26):
In Reply to: S.M gears posted by tractorpullr on November 28, 1999 at 17:03:25:
Consider this-----you are not going to be able to get a lower gear ratio with one gear---you will have to have a least two made, as I figure it. The 44 tooth gear can be enlarged or reduced, but what happens to the gear that it drives or that drives it??
Post A Followup
: Re: Re: S.M gears
