Re: IH 966 MORE POWER!!!
Posted by captaink on February 14, 2005 at 07:01:07 from (66.115.214.56):
In Reply to: IH 966 MORE POWER!!! posted by T.L. Guthrie on February 11, 2005 at 16:39:03:
More power, for PTO work or pulling equipment? If for pulling equipment, the rear end will have it’s limitations and may end up being the weakest link, but I’ll let you decide. When I overhauled my 966, I swapped out the 414 crank for a 436 crank and ordered in the 436 piston kit. My block was drilled for the oil passages for the bottom of the pistons, so I opened them up (if I remember correctly, you just need to knock out a little steel ball) for the additional cooling. There is also a difference in the heads, but I left my original on. I added a 1066 turbo, fuel tank, air filter, and right hood side. I put in a 1466 radiator, flywheel, and clutch (add the hydraulic assist option if you have the tractor under a loader) and possibly some other parts that I don’t remember. Now, with these modifications you can open the pump and get 150 plus HP out of that engine easy enough if you want, but don’t expect the tractor to hold together if you do. I did not open up the pump, as I was going for more economy for light loads at high RPM, and more lugging power at lower RPM and got both and am very satisfied with my results. The modifications made it a whole different tractor for doing loader work and other light high RPM work. The longer stroke was really noticeable when running the tractor on the silage cutter. My 2 cents…
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
