Farmall Tractors Discussion Board
Re: Farmall MD Starter
Posted by Farmer Bob on November 30, 1999 at 22:03:14 from (207.227.187.117):
In Reply to: Farmall MD Starter posted by Roger on November 30, 1999 at 19:11:56:
Roger, You didn't say what was wrong with the original starter but I'd think it may be cheaper to have the original one at least looked at by a auto electric shop to determine repair vice purchase new/rebuilt. Sometimes its a simple problem that can be repaired at little expense, then again it might be cheaper to go with rebuilt.
As far as rebuilt goes, check with Ken Updike at Carter & Gruenwalt Case/IH at (608)455-2411 or Central Tractor at 1-888-828-3276. Their stock # for the rebuilt starter is 90149-233 @ around $220.00 plus a $10 core chg. Good luck. FB
Post A Followup
: Re: Re: Farmall MD Starter
