Re: 1486 T/A out
Posted by the tractor vet on February 15, 2005 at 18:33:35 from (4.124.67.59):
In Reply to: 1486 T/A out posted by Spencer on February 15, 2005 at 17:56:36:
Check them all and for sure replace the PTO input bearing and also the input shaftand all the seals . When instaling the T/A do a dry fit and install two bolts into the Quill and check the end play and shim as needed and also if a shim is needed then shim the gear on the bottom shaft the same. . If ya need more then .100 then get another T/A assy. Go thru the valve body and install a new spring kit and set the pressures at 265-280. Make sure that you get all end play out of the bottom shaft by tighen up the nut tight then back off and then snug up drill and pin the nut to the shaft with a 1/8x1/4 roll pin.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
