Re: 1486 T/A out
Posted by JJK on February 15, 2005 at 20:48:00 from (216.189.131.164):
In Reply to: 1486 T/A out posted by Spencer on February 15, 2005 at 17:56:36:
The bearing that I always check is the one on the pto gear, lot of times it gets loose and spins in the cage, and I recomend replacing both bearing and cage if this applies. If the splines on the quill gear have the dimple marks in them, replace it, and I've gone with the Ag Parts gear cause it comes with bearings in it for a few bucks less than IH's with no bearings. Most everything else I replace with IH parts. About the nut on the countershaft I personally don't like the Hy Capacity trick drilling and putting in the pin. I wrecked a countershaft one time when I didn't notice the pin right away. What I do is clean the threads with brake clean and use some hi strength loctite and tighten down the nut so it draws everything up tight and don't back off the nut. You don't want the spacers coming loose and spinning (seen this happen) cause there's one gear that will walk into the TA drum. I hope I don't get any nasty grams about me knocking somebodies method cause they've never had any problems or comebacks cause I don't either. As we say at work "Its your overhaul", so do it the way you want I guess. Other things I like to do in assy of the TA is take 3 long 3/8 studs, put 1 in the top hole in the bell housing, the other 2 in the quill gear housing, and you can slide the TA assy straight in using the studs to guide it in. Another is use medium strength loctite on all the 3/8 bolts in the bell housing. The 5 on the TA flange, the 3 on the pto gear cage(prevent from working loose), and especially the 4 on the bearing cap(these like to leak oil). Make sure the bolts and holes are clean of grease and oil before using loctite incase you didn't know. Some other things to check while your at this point are the shift forks, components in shift cover, cab mounts, TA cable, clutch booster, clutch linkage, rear engine seal, MCV, and MCV pump. Bad cab mounts and clutch linkage pivot bolted to the bell housing causes a jumpy clutch. Updating to Magnum cab mounts and a linkage kit the bolts to the cab eliminate this. This might be more than you care to know but I hope this helps you out.
Home
| Forums
Today's Featured Article -
Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
