Re: Checking generator
Posted by Bob M on February 16, 2005 at 04:52:31 from (151.190.254.106):
In Reply to: Checking generator posted by the red man on February 15, 2005 at 20:28:29:
Easiest way is to use the multimeter to take a voltage reading directly across the battery terminals. Then with the engine running at governed RPM, ground the "F" terminal on the generator. If the meter then shows 6.8 volts or higher your generator is working fine.
Also punch below for a troubleshooting chart that might be helpful...
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
