Re: IH 826 Hydrostatic drive
Posted by JJK on February 16, 2005 at 18:23:48 from (216.189.131.124):
In Reply to: IH 826 Hydrostatic drive posted by AlaskaRancher on February 16, 2005 at 16:27:56:
If the filter isn't plugged or froze up I would maybe go after the hyd pump located on the right side of the hydro housing if I'm remembering right. Possibly the key sheered on the pump shaft or the nut came loose and the key fell out. I don't think it would be the flex plate on the flywheel cause you mentioned that the pto works. If everything seems to check out ok then there may be a leak on the suction side and sucking air.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
