case/IH 695 forward/reverse clutches
Posted by corey c. on February 17, 2005 at 14:27:52 from (208.28.113.26):
got a 695 with mfd that slips in forward, more so in reverse. Wont pull itself in reverse. Split tractor and took forward/reverse unit out and took it apart. Found that the screws that hold the pistons together had backed completly out. Installed new pistons/plates and disc's. Installed new seal rings in the pistons and clutch shaft. When i blow air into the oil inlet of the carrier..it doesnt hold good pressure. The clutches seem to lock up when i put air to it and move the spool. Just sounds like it leaks to much. The ring lands on the carrier and shaft seem fair. I have taken the unit apart again to make sure i didnt break the 3 seal rings on the clutch shaft,,,the were ok. Is this leakage normal? Does the aqpprox. 320 psi seal the unit good enough?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
