Re: B414 Diesel Smokes, No Power - HELP!
Posted by K.B.-826 on February 17, 2005 at 18:50:30 from (209.163.30.69):
In Reply to: B414 Diesel Smokes, No Power - HELP! posted by Dan Caldwell on February 17, 2005 at 17:00:36:
Let's start with the easy things first. Got a good flow of fuel out of the tank? Fuel filter been changed recently? Is the air cleaner clean? Inspect the entire intake system for obstuctions. Since it just had a head job, double check the valve lash adjustments. Have you checked the injection pump timing yet? If you have the correct compression adapter/guage, do a compression check just for the heck of it. If you don't get anywhere after checking these things out, it's time to send the injection pump out to be rebuilt, I'm guessing that's the problem.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
