Re: B414 Diesel Smokes, No Power - HELP!
Posted by JT on February 18, 2005 at 07:44:17 from (69.220.199.9):
In Reply to: B414 Diesel Smokes, No Power - HELP! posted by Dan Caldwell on February 17, 2005 at 17:00:36:
Did you pressure test the injecters when they were out? Is your spray pattern, even, or is kind of slobbery? If it starts and runs on its own, then your compression should be OK. As others have said, it could be a pump. I know this is not the answer you wanted to hear, but if I was having these problems, I would probably take the injectors and pump and have both checked. More than likely it is one of the two and if you are going to keep the tractor, it is a sound and good investment to have this done.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
