Re: H$ Magneto Impulse Coupling Flush with Kerosen
Posted by MagMan on February 18, 2005 at 16:52:25 from (205.188.117.13):
In Reply to: H$ Magneto Impulse Coupling Flush with Kerosene posted by Scott Swanson on February 18, 2005 at 12:16:29:
Hi Scott,
The front greese cup on an H4 mag is plugged with wick or felt you use a few drops of oil every now and then so the greese does not dry up in the rotor gear. As far as the rear there should be no restriction there You can give it a few good squirts of oil to lube the trip mech. While it running on the tractor is the best so it work in but a turning over speed so the trip is ingauged . As far as the kero You cantake the mag off and squirt some kero around and behind the trip and turn it over and let it clean some of the greese and junk out of the trip then blow it dry and put it on and lube it with the light 3 and 1 oil .If your trip works ok and is crisp just give hera few shots of the 3 and 1 oil> I would get something to stick in the iol cup and pull the restriction out of the rear cup or if its greese just use a piece of wire to get it cleaned out. If you need help let me know.
JON
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
