Re: IH 1066 hydraulics problem
Posted by the tractor vet on February 18, 2005 at 20:10:54 from (4.124.69.215):
In Reply to: IH 1066 hydraulics problem posted by Willy P on February 18, 2005 at 18:37:59:
Pull the top link plate off and Look inside and on the right you will see and lever hanging down and a lever -rod arm what ever ya want to call it the top one should be on the back side of the bottom one use a hook or pice of baler twine , wire what ever to pull the top one back and put it on the back side .
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
