Re: 1086 Question
Posted by JJK on February 18, 2005 at 20:31:21 from (216.189.131.234):
In Reply to: 1086 Question posted by Tom in Michigan on February 18, 2005 at 03:19:03:
The fuel guage reading 1/4 tank will most of the time be the sending unit, just grounding the wire will only make sure that your guage works but gives you a good guess that the sender is bad. If you have a little volt meter you can easily check the sender. With the sender out of the tank and the volt meter set to check ohm's put one lead on the ground and the other on the screw. Lift the float up and down and the needle on the meter should move smoothly like a guage. If it don't then the sender is shot. The ground speed sender is located under the seat in the range cover. You might be able to take the floor panel out and look to see if you can find the plug end. Try unplugging it and clean the connections, if this still don't work then you might need to replace the sender. 5 bolts and the seat will lift up (I tip the seat onto the back ledge hanging out the rear window just far enough that it don't fall out and unscrew the big hand nut on the steering wheel to remove the steering wheel helps make room to work). To install the sender, you screw it in till it hits the gear and back it out 1/4 to 1/2 a turn, and then tighten the jam nut. Hope this is enough info for ya.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
