Re: Low RPM kit for Delco 10SI alternator???
Posted by JT on February 19, 2005 at 11:36:56 from (69.220.199.9):
In Reply to: Re: Low RPM kit for Delco 10SI alternator??? posted by Brian Schmidt on February 19, 2005 at 06:41:17:
Generators need to turn a minimum of 1200-1400 engine rpm to charge. If an alternator will not charge at low RPM as you say, how do diesel engines sit and idle for hours at 1000 rpm and keep, heaters, lights, etc running at a truck stop? If alternators do not charge at low rpm, then why do healights not dim at an idle where they do with a generator? What are you calling low rpm?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
