Re: Starter won't kick in
Posted by Chris in Fredericton on February 20, 2005 at 04:03:30 from (69.195.193.243):
In Reply to: Starter won't kick in posted by Randy Mc on February 19, 2005 at 12:34:45:
Just got done needlessly chasing an electrical problem on a 454... would only get a click every once in a while when trying to start it, then it would come clear and start. I took for granted that the positive battery cable and connector was OK because it looked that way. It was an old stiff large-strand #2 cable. Replaced with a new #2 welding type cable and a new connector and now it starts and charges like a "new" tractor. I should have been checking for 12 volts at the solenoid when cranking... wouldn't have seen it with the old cable. Perhaps you should try using a voltmeter instead of a "light". Make sure you see your battery voltage at the starter. You'll find it,I'm sure!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
