Re: Shift Lever
Posted by Hugh MacKay on February 20, 2005 at 08:55:14 from (64.228.11.7):
In Reply to: Shift Lever posted by PAULIH300 on February 20, 2005 at 08:39:16:
Paul: It will be a lot easier to reinstall if you start with tractor in neutral. When you set back in place and all rails are lined up in neutral, very easy to find the neutral position. If it is same as Farmall just set the base back loosely put in the three bolts, hold down on base and you should be able to shift through all gears, before you tighten it down.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
