Re: W4 question for Hugh and others
Posted by CNKS on February 22, 2005 at 19:03:52 from (204.249.178.138):
In Reply to: W4 question for Hugh and others posted by Jeff In Ontario on February 22, 2005 at 18:35:44:
I don't follow you--most people pull start because the battery is dead. If it doesn't turn over with the starter, make sure the battery is fully charged and that all the connections are clean. In other words take each connection off from the starter, battery, and starter switch and clean them. Use large battery cables, minimum 2 gauge. If it doesn't turn over then you probably have starter problems. It should also start fairly easily with the hand crank if you have one. You can determine if you have valve problems or ring problems by running a wet and dry compression test. Even if it doesn't smoke out the exhaust, significant smoke from the draft tube (by the oil filter on the right side of engine) is an indication the engine is getting worn. It may not smoke much from there until the engine is hot. Might be a good idea to adjust the valve lash also. The engine has to be in pretty sad shape not to start.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
