Re: 8 Volt battery on M
Posted by Josh in Indiana on February 24, 2005 at 18:34:34 from (65.112.65.110):
In Reply to: 8 Volt battery on M posted by Buzz on February 24, 2005 at 16:25:04:
hi Buzz,
Pop and I did a 6 to 8 conversion on his 1947 Hudson.(name from the past..lol). Anyways, it was done about 4 or 5 years ago and we havent had to replace a bulb yet. The guys at the parts store tell me that a 6 has more cold cranking amps than a 8, so if your concerned abotu that it might be worth looking into. All i can say is it has worked well for us. Im sure it would work just as good in your M.
Good luck
Josh in Indiana
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
