Re: 8 Volt battery on M
Posted by Doug in OR on February 24, 2005 at 21:55:41 from (24.20.250.197):
In Reply to: Re: 8 Volt battery on M posted by El Toro on February 24, 2005 at 17:11:30:
I maintain the communications gear on our rather large fleet of law enforcement vehicles. When I get a car in (mostly Fords) that has an alternator output of 15 volts, I immediately send it to the shop for an alternator replacement. Not only does the 15 volt output cook the batteries, it tends to wreak havoc on the overvoltage protection zener diodes in my comm gear. Equipment designed for 12 volts is really engineered to run on 13.8 volts. The maximum voltage I will allow is 14.5 volts - and even there the batteries start using water.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
