Re: 8 Volt battery on M
Posted by farmalljim10 on February 25, 2005 at 03:58:27 from (66.244.93.65):
In Reply to: 8 Volt battery on M posted by Buzz on February 24, 2005 at 16:25:04:
I have done this in the past and I have never had a problem with the lights Just make sure you set up the voltage regulator to about 9 to 9.4 volts.Other wise you still end up with 6 volts.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
