Re: Sleeve Puller for an A or B
Posted by El Toro on February 25, 2005 at 17:17:14 from (64.12.117.13):
In Reply to: Re: Sleeve Puller for an A or B posted by Red Dave on February 25, 2005 at 11:56:17:
Hi Dave, You can drive out one those sleeves
after you remove the piston. When I restore an A
the pistons were seized and I soaked them with
transmission fluid. Two pistons came with the sleeves and the other two pistons came out without
the sleeves. I had a puck made and they came out too. Once they clear the sleeve seals you can
probably lift them out by hand. They're not pressed in like the dry sleeves.
I have sketch, if you would want a copy I'll mail it to you. You can either pull the
3.0" sleeve or the 3.125" with one puck. If this
was an original A they would accept the 3.125"
sleeves without any machining. That's the size I used in mine when I redid the engine. I just used the old connecting rods off the old pistons
and had the machine shop to install them on the new pistons. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
