Re: Need help with my Farmall
Posted by Paul in Mich on February 26, 2005 at 04:18:10 from (66.188.26.29):
In Reply to: Need help with my Farmall posted by Phillip Peterson on February 25, 2005 at 19:22:38:
Phillip, The "C" had a plate rivited to the right side of the tool box under the seat which had the serial number stamped on it. Biggest problem there is that IH may have well rivited it to the clutch pedal, as they did get scuffed up a lot and are a bear to read after 50 odd years. The H and M had a plate on the left side of the clutch housing. If you dont find a plate, then take Cowman"s advice and start looking for that machined surface on the engine, which by the way, may not look so smooth if it has a bunch of paint or curd built up. Nevertheless, there is one, and there should be a stamped number once you get past said paint and crud.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
