Re: HELP Farmall H
Posted by El Toro on February 26, 2005 at 13:41:45 from (205.188.117.13):
In Reply to: HELP Farmall H posted by mattla on February 25, 2005 at 13:31:45:
Bring No1 piston up on compression stroke and until the timing mark on the pulley is aligned with the pointer. Then see if the rotor is pointing to No1 plug in the distributor. If this looks ok check your plug wires. With a distributor your rotor turns CW and the next plug is No3, then 4 and 2. If these are ok. Squirt
a little gas into No1 sparkplug hole and see the engine tries to start. If it does you aren't getting fuel into the combustion chambers. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
