Re: Brakes (Help Again) Please!
Posted by Mike ISW on February 26, 2005 at 18:39:32 from (64.12.117.13):
In Reply to: Re: Brakes (Help Again) Please! posted by Tailhunter on February 26, 2005 at 18:10:05:
Hey, don"t get excited....we"ll all help as much as possible! Good job on the bull gear removal. Quite a chunk of iron hey? While you"ve got the pinion cage out replace that bearing...available at CNH dealer. I installed 2 seals on each side as the new and improved ones are 1/2 wide as originals. Didn"t want to do that job again on same tractor. remember to reinstall metal shims as removed (if any) behind pinion cage. As for reinstalling deck lid i had not removed shift lever and had placed it in neutral and placed sliding gears in trans as close to neutral as possible. This is a 2 or 3 man job installing as things need to be lined up as you go on with lid. In my case I had everything sealed up except for the lid on and I poured in 6 gallons of gear lube seemed easier than pouring in with a funnel. If in need of more suggestions just yell........Mike
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
