Re: 454 charging problem
Posted by JB2 on February 27, 2005 at 08:09:39 from (24.157.143.220):
In Reply to: 454 charging problem posted by n8terry on February 26, 2005 at 21:53:29:
Hi N8Terry, the 454 originally had a generator.
Did you do the alternator conversion? I know on my brothers 454 when we converted to a Delco alternator, the simplest solution was to run a new wire to the battery connection on the starter bypassing the voltage regulator and amp meter circuits. The amp meter only shows discharge when switch or lights are turned on.
Could this be your problem ?
Good luck
JB2
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
