Re: Poor First Farmall H
Posted by PA Steve on February 27, 2005 at 18:55:21 from (4.247.60.51):
In Reply to: Poor First Farmall H posted by colekicker on February 26, 2005 at 19:26:06:
I would start by disassembling the entire rear end. Often times you can get individual parts loose that won't turn when they're together. If you clean the gears and splined shafts the best you can and get the bearings moving and then put it back together with new gear oil, it will run for you. If any parts are real bad (severely pitted), they should be replaced.
One more thing, it is best to just drive on the level for a little bit in each gear at first. It will help to minimize load on the bearings while the gear teeth are polishing themselves.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
