Posted by JimB2 on April 05, 2009 at 07:28:51 from (99.240.236.11):
In Reply to: IH 674/684 posted by clampit on April 04, 2009 at 22:45:07:
Hi, the only area that is different between 674/684 is the spacing of the mounting holes on the casting in front of the rad. We attempted to put a front cast weight from 674 on 684 and holes would not line up. Some loaders only use the sde mounting holes which are the same. We moved a 2250 from 495 to 3230 and we had to drill two new holes in front mounting plate.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
