Re: Anybody a diesel mechanic?
Posted by Bob on March 01, 2005 at 11:25:46 from (66.163.134.177):
In Reply to: Anybody a diesel mechanic? posted by Curt Cooke on March 01, 2005 at 11:02:42:
Check your camshaft (valve lift).
Run it, warm it up, work it some, to break in the engine. If the problem continues, do a compression test, if that's OK, swap the injectors between the offending cylinders , and a couple that are firing better, and see if the problem moves with them, or stays with the same cylinders..
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
