Posted by Bob O2 Martin on April 05, 2009 at 07:49:44 from (69.66.16.186):
In Reply to: Farmall H bendix??? posted by beochie on April 05, 2009 at 07:21:22:
First pull the starter, ground the case and jump onto the current feed for the starter. See if the bendix is sliding up the shaft. If it isn't, lube the shaft with a penetrant/lubricant. a lot of times that takes care of the problem.
If you have to remove the bendix, take out the two long bots that hold the starter together and pull off the starter head. There is a little clip that you take off and the bendix will slide off. Reassembly is pretty simple.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
