Re: Farmall 706 310d antifreeze problem help ple
Posted by Trent R. Young on March 02, 2005 at 08:12:24 from (205.238.248.178):
In Reply to: Re: Farmall 706 310d antifreeze problem help ple posted by K.B.-826 on February 28, 2005 at 18:44:20:
I'm to the part where i'm removing the sleeves to see whats really going on for sure. I have one piston out and the sleeve does not want to move. The book tells you to use a block of wood and bump it out. There is hardly enough room to get anything in let a lone wood. I'm thinking maybe a long aluminium punch. cast sleeves or steel because cast would possibly break. Also because of the shape of the rods you have to un bolt the rod cap and bottom of piston stroke and rotate to top of stroke to clear the crank. At least thats what i did to remove the first piston. any help would be apppreciated. thanks
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
