Re: 826 Hydro,
Posted by K.B.-826 on March 05, 2005 at 09:44:00 from (209.163.43.32):
In Reply to: 826 Hydro, posted by Dave From MN on March 04, 2005 at 14:20:50:
The engine is the six cylinder version of the 239 in your 544. If you are not happy with tractors that will not start without a circulating tank heater, you will not like the 826. Like Scott said, the Hydro is great for loader work, haying, planting, spraying, harvesting, and other PTO jobs where it is nice to be able to vary ground speed without changing engine speed. An 826 Hydro would be right at home on a forage harvester with a 2-row corn head. Hydro's are just about worthless for heavy tillage work, pulling them hard generates a lot of heat. Our 8 is a gear drive, probably one of the best all-around tractors out there.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
