Re: I-300u identifing year?
Posted by PAULIH300 on March 05, 2005 at 11:04:21 from (205.188.117.13):
In Reply to: I-300u identifing year? posted by Steven Donahue on March 05, 2005 at 11:00:09:
Sure sounds like a 1955.The 300s and 350s used the same carb kit.So you dont need the year.Just make sure its a I-300(300U) with a C169 engine.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
