Farmall Tractors Discussion Board
Re: Farmall-M
Posted by The Red on December 03, 1999 at 10:01:39 from (206.246.187.2):
In Reply to: Farmall-M posted by Brain on December 03, 1999 at 09:29:43:
Brain it sounds like you had the duel fuel settup on that M. Must be an early one. That sounds like the auxiliary fuel tank that was used to start the M on gas, then you could switch over and run it on distillate or kerosene from your main tank.
Post A Followup
: Re: Re: Farmall-M
