Re: 1976 Cub Lo-Boy oil leak
Posted by Denny ('60 Lo-Boy) on April 05, 2009 at 09:48:17 from (71.53.61.121):
In Reply to: Re: 1976 Cub Lo-Boy oil leak posted by Jiles on April 05, 2009 at 06:23:36:
It"s next to impossible for transmission gear oil to be leaking out the gear shift lever if it is filled to the correct level. The oil level is 3-4 inches below the top of the trans. On the left side of the transmission is a small plug that is the proper level for the oil. It is only 3 1/2 PINTS, or 1 3/4 qts. Definitely recheck this level.
