Re: 460 Water Pump
Posted by captaink on March 08, 2005 at 06:59:56 from (66.115.214.56):
In Reply to: 460 Water Pump posted by GooseCreek Farms on March 08, 2005 at 03:28:50:
Normally, when you see coolant dripping from the weep hole on a water pump, its time to either replace it or rebuild it depending on availability of parts and equipment to do the rebuild (usually a press is required).
What typically happens is either the seal gets hard and/or worn out, or the water pump bearings get loose enough to allow the water pump shaft to move far enough to allow the coolant to leak by.
Good luck.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
