Re: Distributor questions
Posted by MagMan on March 08, 2005 at 11:48:33 from (64.12.117.13):
In Reply to: Distributor questions posted by Tanner Clark on March 08, 2005 at 10:57:10:
Hi Tanner yes most of the IH distributors are the same except for the fact that they are set up with different advances from the factory you get into them and its marked on the advance weights. And if you look in the It manual it tells what advances were used on what aplications. As far as you post below Kim the Moderator tryed that kind of forum last fall and Some of us excepted it and some didnt then it just went off after a few weeks and she said she was having some difficulties with the new and I have not seen anything from it or her actually since then.The best way that I see to use it is to post with your email and check the box below so you will know when someone posts below you even if its a week from now. JON
JON
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
