Re: Oil is gray after overhaul
Posted by Sloroll on March 09, 2005 at 06:56:00 from (69.66.85.73):
In Reply to: Re: Oil is gray after overhaul posted by Allan in NE on March 09, 2005 at 06:42:43:
I have gotten the gray after condensation in spring when temps/humidity run high and the cast is still cold. I got gray when I resleaved an F-14. it dissapearsd after awhile, I suppose as the sleaves settled in. A large amount of water (why I resleaved the F14) foams new oil to almost whitish green.
I agree that the oil and filter should be replaced. If the gray comes back, Did the head get retourqued after the engine was run up to temp? Was the head gasket put on correct side down. Was the head and block cleaned thouroughly?
I hope it is gunk getting flushed out. It is a good posibility it is. Change your oil and keep an eye on it.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
