Re: touch control help please
Posted by Hugh MacKay on March 09, 2005 at 17:37:07 from (64.228.12.166):
In Reply to: Re: touch control help please posted by gray on March 09, 2005 at 17:05:11:
gray: You'll notice at bottom of hydraulic lever, linkage going to touch control has an adjusting end. Sometimes these need a bit of adjustment as lever is not syncronized with rockshaft movment. Usually that is a case of rockshaft reaching end of stroke and lever trying make it go further. Unless I'm misreading you, I somehow don't think that is your problem. How long is it since your touch control fluid has been changed? And how long since screen was cleaned? What happens if you hitch to a plow or some implement similar weight, is problem worse or better? Another item to check is spring assist for hitch, it has adjustment that can be off? The long bolt going into spring from end, if not adjusted properly can stop rockshaft before it is all the way forward. Just play with it a bit keeping close watch on changes and when they occur. Process of elimination. It may well be your touch control needs a kit, but we should explore other possibilities first. Usually the kit happens when problems occur on both valves.
Home
| Forums
Today's Featured Article -
An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si
... [Read Article]
Latest Ad:
Variable pulley for case 1530 skid loader
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
