Re: can't get my M to start
Posted by Jim Broughton on March 09, 2005 at 20:36:03 from (4.243.7.123):
In Reply to: Re: can't get my M to start posted by Nebraska Cowman on March 09, 2005 at 17:51:58:
You didn't say what year your "M" is...so check on the carb at the float chamber...if there is a "brass nut" on the outside of the float chamber, unscrew it and clean out the jets...now there is a long jet that runs horizontally thru that brass fixture...and if it is stopped up, it will not run!! You will need a very small needle to run thru that jet...or use an acetylene torch cleaning tool (wire) and once that jet is clean...she'll run!!
Lotsaluck !
Jim
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
