Re: International oil/hydraulics
Posted by Haas on March 10, 2005 at 06:04:28 from (12.65.60.139):
In Reply to: International oil/hydraulics posted by reid man on March 09, 2005 at 19:35:52:
The 424 has a separate reservoir for the hydraulics. That is it does not use the transmission oil for the hydraulic system. Therefore, you can use tractor fluid (HyTran) in the hydraulics, and if you want to, gear oil(any 80-90W or 90-140 oil will work) in the transmission. However, you can also use the HyTran in the transmission and that may be best to avoid any confusion. I don't know the capacities, but I think the hydraulics are about 3 gallons. I owned a 424 for a few years. Good utility type tractor. Main reason I sold it was no power steering. Note also that the early models of the Mahindra tractors are almost exact copies of the 424 and many parts interchange. Mahindra parts are cheaper than from IH.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
