Farmall 706 has low hydraulic pressure to aux. val
Posted by John2005 on March 11, 2005 at 17:54:57 from (64.136.49.228):
I have a farmall 706 and it has very low pressure to lift an implement to the aux. valves. 3 point seems to work ok. Is there a pressure control that may not be working correctly or need adjusted?
Any help would be appreciated
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
