Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Unleaded fuel
Posted by Wooden Shoe on December 04, 1999 at 06:59:40 from (152.163.197.53):
In Reply to: Re: Re: Re: Re: Unleaded fuel posted by Tim W on December 03, 1999 at 19:20:19:
I am a new guy just bought a 1954 Cub I think but I do know somthing about Tetraethyl lead in fuel. It was added to gas for two reasons. Lead served as a lubricant to the valve guides and also the valve seats, and the second reason it was added was to raise the anti-knock value of the fuel. Which is another way of saying raising the octane value of the gas. I would think if you are not really working the tractor hard it won't make any differance at all. If you are working the tractor hard listen for detonation - some call it pinging. This can cause burned pistons, and other problems related to high cylinder temperatures. As for the valves, it usually takes a long time of hard running to affect them but the additives may stave off the final solution of replacing with harden valves and seats.
Post A Followup
: Re: Re: Re: Re: Re: Re: Unleaded fuel
