Martin Caldwell diverter valve help
Posted by Bobcat on March 13, 2005 at 06:04:16 from (69.66.79.98):
My Farmall 450"s diverter valve is worn-out! I would sure be interested in knowing what universal flow divider you used and how to plumb it into my system. I bet there are alot of 300"s-450"s out there that could use your fix!
Did you try machining a new valve on a lathe and putting it into your old valve? My valve is worn on the ends and the center seems alright so I could use that as the diameter on the ends. Maybe the bore is worn as badly as the valve so if you"ve tryed that I wont bother.
Sure would like to see what you have on yours now!
Thanks! Dave E-mail is open
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
