Re: Where can I get exploded views and part numbers?
Posted by Bob on April 05, 2009 at 12:22:20 from (69.178.228.68):
In Reply to: Re: Where can I get exploded views and part numbers? posted by bruce wayne on April 05, 2009 at 12:17:01:
CNH/CIH = "FIAT", the current parent company of IH, Case and New Holland.
Go to CNH.Com.
Then, select CASE?IH, the select your area, and drill down through the menus 'til you get to "search for parts".
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
