Farmall Tractors Discussion Board
Farmall M liftall pump
Posted by Ralph Thomason on December 04, 1999 at 17:32:05 from (162.39.156.149):
Can someone give some advice on the seal on the liftall pump drive .All I can find is a single lip seal ,will that be enough to hold against that much pressure ?Is there a seal that goes around the shaft that comes out the side of the reservoir for the control rod to hook up to? Thanks Ralph
Post A Followup
: Re: Farmall M liftall pump
