Re: Hung in gear
Posted by Andy Martin on March 15, 2005 at 15:03:25 from (64.219.39.195):
In Reply to: Re: Hung in gear posted by dej(JED) on March 15, 2005 at 09:43:24:
If the pin does not want to come out, push down on the shift lever. The pin may have a groove worn in it and you will need to relieve the spring pressure to get it out. There is no need to hammer very hard on it, most of them are loose once you get the spring pressure off.
The other method is to try to put the lever back into high gear. Feel around while pulling down and right with the lever and you may get it back in, if you do, hold the lever to the right to shift back to neutral.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
